What is the best Anime Setup?
Which Rife Version, mpv config, svp config, etc.?
At the moment i use:
https://www.svp-team.com/forum/viewtopi … 352#p83352
with Rife 4.22(v2) and newest TensorTR library -> v15.2.
My MPV Conf:
# THIS FILE WILL BE OVERWRITTEN WITH THE PACKAGE UPDATE
# Use %APPDATA%/mpv/mpv.conf
# OR SVP's menu -> Information -> Add. information -> mpv config. file
# to define your own customized configuration
# Sample mpv configuration
# this is required for SVP to "catch" the mpv
input-ipc-server=mpvpipe
# hardware video decoder
#hwdec=auto-copy
hwdec-codecs=all
hr-seek-framedrop=no
no-resume-playback
vo=gpu-next
# high quality video output, require rather fast video card
profile=gpu-hq
# D3D11 renderer (default) is required for the HDR playback
gpu-api=d3d11
# use VULKAN API if you have problems with the default d3d11 renderer
#gpu-api=vulkan
# miscellaneous options
# comment this one if you want mpv to remember the playback position
save-position-on-quit=yes
# fixes audio desync
# "ReClock" replacement
#video-sync=display-resample
#video-sync-max-video-change=5
#log-file=mpv.log
# Deband filter. Always turn on for anime.
deband=yes # Default values are 1:64:16:48
# Deband parameters configuration.
deband-iterations=2 # Range 1-16.
deband-threshold=35 # Range 0-4096.
deband-range=20 # Range 1-64.
deband-grain=5 # Range 0-4096.
dither-depth=auto
# Optimized shaders for higher-end GPU: Mode A (HQ)
glsl-shaders="~~/shaders/Anime4K_Clamp_Highlights.glsl;~~/shaders/Anime4K_Restore_CNN_VL.glsl;~~/shaders/Anime4K_Upscale_CNN_x2_VL.glsl;~~/shaders/Anime4K_AutoDownscalePre_x2.glsl;~~/shaders/Anime4K_AutoDownscalePre_x4.glsl;~~/shaders/Anime4K_Upscale_CNN_x2_M.glsl"
What are your favorite MPV scripts?
My SVP settings:
