1 (edited by AndreaMG 06-04-2016 19:29:41)
Topic: SVP4 Pro Auto-update madVR not working
Hi there, my SVP4 Pro is bond with MadVR v. 0.90.15 while the current version is 0.90.17, why is not auto-updating? Am I missing something? Thanks smile
Re: SVP4 Pro Auto-update madVR not working
Just wait a some time. It will be updated soon. smile
madVR is at ver. 0.90.17 since 27-03-2016
I can see in the updates list, both in the Manager and in the Maintenance tool.
4 (edited by AndreaMG 07-04-2016 11:53:59)
Thank you guys I think the problem might be that the entire SVP is not auto updating because it reports 4.0.072 any idea on how to solve it?
Besides if I launch "svp4-maintenance.exe" it says no updates are available...
Thanks smile
> it reports 4.0.072
Free version is at .72 now, Pro should show an update to .73
I can't imagine how this could happen IF you really don't have SVP .73 and madVR .17 installed (in this case "installed" == "listed in the components.xml file")
6 (edited by AndreaMG 07-04-2016 19:22:42)
Thanks Chainik, It's funny because Madvr folder inside SVP shows last version and even "components.xml" shows SVP Manager (Pro) application Version 4.0.0.73 smile
But when SVP 4 Manager is launched it's the previous version (together with MadVR old version V. 0.90.15 (127.0.0.1)): mad
Date and time: Thursday, 7 April 2016 21:13:34 ora legale Europa occidentale
SVP version: 4.0.0.72/Windows
Screenshot1.PNG, 146.71 kb, 677 x 455
Screenshot3.PNG, 94.33 kb, 655 x 424
7 (edited by AndreaMG 07-04-2016 19:21:05)
Here's attached the log smile
it there any chance you have TWO installations in a different folders?
Reinstalled now everything looks OK smile
Thanks for the awesome program cool
reinstallation isn't a solution but just an evasion of the problem
I might mention it here although I don't know whether it has been fixed already.
Some time ago, I manually updated the madVR folder with a newer release. Afterwards, SVP said there was an updated version of madVR but failed to update. There was no way to get the update to work. The only solution was to copy back the original folder of madVR (luckily I kept it), and then let the update manager update it from there.
Yeah!
It's because of the "pause" command at the end of "uninstall.bat" wink
it hangs the uninstallation of the previous version by the Maintenance tool
