Topic: Flickering videos with RIFE AI (likely caused by TTA)
Hi everyone!
I don't know where to start, so let me just start with the background.
I recently switched from using Linux to using Windows for SVP (Evaluation version). The reason I switched to Windows is pretty easily explained, RIFE needs version 210 which is not yet on Linux, and after I tried it on a Windows VM, it explained me it needed a GPU with Vulkan API which VMWare failed to provide. After spending hours gaining that knowledge, I installed Windows on a free partition and SVP installed without any issues. Also: The normal vapoursynth (non-RIFE) script never caused any issues, neither on Linux, nor on Windows VM nor on native Windows. It's the safe bet, but who's not willing to try something new?
-The Problem-
I configured the profile for higher quality (TTA on, FP32) and left everything as is, started the transcode and voila, it did actually start (the magic 1%)! Curious as I am, I opened the not-yet-finished file (read-only) in VLC, and I was surprised to see that it was flickering, and looking at it frame by frame told me every second frame was just black. Though the water mark was still there, to help troubleshooting  . VLC told me the framerate is 24000 (sic!) with the original having 23.976024 fps. So I closed VLC, waited for it to be done transcoding, hoping that it would add these frames later on. But nothing changed. Despite the seemingly high framerate, the playback speed and seek bar times were correct, and I only had to go 48 frames forward to get to the next second. The log (attached) told me about some issues that I have no idea of. Task Manager told me 0~5% GPU load, 95~100% CPU load. Isn't that odd?
Also while writing this, I tried using the default settings and I think TTA causes this issue. Turning it off seems to get me a better video (I see interpolated frames, no flickering) and it takes a lot longer than before. If anyone needs snapshots in case they can't reproduce my error, I'll happily share some frames. Same goes for any logs/system information etc.
System Specs:
CPU: 3600
GPU: RX 570
M.2 SSD
RAM: 16GB DDR4
Windows 10, drivers and everything up to date
SVP 4 version 210
Thanks a lot
Super4Jet
Also since the attachements don't seem to work as far as I can see, here's the log on pastebin: https://pastebin.com/eTuX27Wz
