Topic: SVP can't find my GPU?
I'm using SVP 4 with a Geforce gtx 760, which was detected before but now the option to use the gpu is gone! And the "Why GPU acceleration isn't available" doesn't say much about it except for unsupported GPU, which is not my case. Someone got an idea?
Untitled.png, 9.94 kb, 440 x 325
Re: SVP can't find my GPU?
Another user had the same problem; they solved it by running DDU (Display Driver Uninstaller) and re-installing their drivers.
Keep in mind that Nvidia's Windows 10 drivers are considerably poorer than both AMD's and Intel's.
It's been solved, thanks for your help!
