Topic: Problem with TS file
Hi Guys, i am playing a TS file Video.
It has embedded PGS subtitle, i have enabled Subtitles Section in FFDSHOW, but the subs is not showing up.
Anyone can help with this?
Re: Problem with TS file
keeycheng
did you select subs in splitter?
http://www.svp-team.com/forum/misc.php?item=2925
Hi Rimsky, i am using Haali Media Splitter, the Sub is not showing there, it is written No Subtitle.
keeycheng
Perhaps Haali doesn't support PGS subtitles. Try to use LAV splitter for this: launch LAV\install_splitter.bat from SVP folder and reopen video.
seems like Haali is the one playing the fool here.
LAV splitter can play the subtitle with no problem, but now i cant click on the video to choose the time i wanted.
It can only play from beginning to end...and the only interaction i can do is play/pause.
keeycheng
where you get this file?
I want take a look on it
as variant try to remux it with MKVToolnix to mkv. May be this help.
7 (edited by keeycheng 10-12-2013 10:55:43)
Got it from this site, its a chinese video.
http://banyungong.net/magnet/160301.html
DISC 1:
Length: 3:31:09 (h:m:s)
VIDEO:MPEG-4 AVC Video 20979 kbps 1080i / 29.970 fps / 16:9 / High Profile 4.1
AUDIOTS-HD Master Audio Chinese 2817 kbps 5.1 / 48 kHz / 2817 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics Chinese 22.449 kbps
Presentation Graphics Chinese 22.039 kbps
DISC 2:
Length: 1:48:18 (h:m:s)
VIDEO:MPEG-4 AVC Video 22001 kbps 1080i / 29.970 fps / 16:9 / High Profile 4.1
AUDIOTS-HD Master Audio Chinese 2844 kbps 5.1 / 48 kHz / 2844 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics Chinese 16.139 kbps
Presentation Graphics Chinese 15.771 kbps
Said there is menu, but i cant see it using haali as well..
Format                                   : MPEG-TS
File size                                : 36.4 GiB
Duration                                 : 4h 19mn
Overall bit rate mode                    : Variable
Overall bit rate                         : 20.0 Mbps
Maximum Overall bit rate                 : 35.5 Mbps
Video
Menu ID                                  : 1 (0x1)
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 2 frames
Format settings, GOP                     : M=1, N=26
Codec ID                                 : 27
Duration                                 : 3h 31mn
Bit rate mode                            : Variable
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate                               : 29.970 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Interlaced
Scan order                               : Top Field First
Audio
Menu ID                                  : 1 (0x1)
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Format profile                           : MA / Core
Mode                                     : 16
Format settings, Endianness              : Big
Muxing mode                              : Stream extension
Codec ID                                 : 134
Duration                                 : 3h 31mn
Bit rate                                 : Unknown / 1 509 Kbps
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 KHz
Bit depth                                : 16 bits
Compression mode                         : Lossless / Lossy
Language                                 : Chinese
Text #1
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Language                                 : Chinese
Text #2
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Language                                 : Chinese
keeycheng
I try to download it later
Thanks... smile
keeycheng
anytime
but downloadnig speed about 300-400kbyte/sec
I check it as soon as possible
all normal
seekeng work
subs are shown
check used filters as shown
http://www.svp-team.com/forum/misc.php?item=2938
hi can you try with ffdshow raw video filter?
and use haali as the splitter?
keeycheng
seeking works
subs are not
hmm this is weird....
no prob, let me try wiith lav splitter again...
nit to rectify the issue..
